310 RL - Is the MORyde independent suspension worth doing?
I doing research on suspension upgrades I ran across some that say the independent suspensions don't equalize the weight from one axle to the other and that, that harms the overloaded axle. Has anyone with the independent systems seen any repercussions from this?
Another question that I have is, is there much concern of the cost of adjustments to the independent suspension from rough roads or do they respond fairly well to hitting the potholes, etc?
Sorry for all the questions!
Hi. I am not an expert by any means but this is what I know to be true about independent suspension (I'm a hobbyist and have rebuilt suspensions on vehicles and am a geek when it comes to things I am interested in).
Unequal weight distribution is not an inherent characteristic of independent suspension. If the suspension is properly engineered and aligned, and the load is distributed correctly, then weight imbalance issues are minimal. The load distribution element generally refers to the vehicle design itself. However if you add 1K pounds over only one wheel of a trailer with independent suspension it would also come into play. Think of a motorcycle doing a wheelie; the rear suspension is carrying an unequal amount of mass (100% of mass on the rear suspension/ 0% on the front suspension).
Leaf spring suspension is inherently better at equalizing load across axles. This becomes particularly noticeable on uneven terrain. If you think about pitch and roll caused by terrain characteristics, there is a possibility that a majority of mass can be transferred to one wheel with an independent suspension but really difficult with a leaf spring setup. However, if the independent suspension is designed correctly, and the transfer is momentary, it's not a big deal. If this unequal weigh distribution was constant, yes, the wear to that axle would almost necessarily be greater than the other less loaded axles. In this context of an RV, towing ability would also be reduced with weigh concentrated over one axle.
Independent suspension is better at high speed hits (impact that compresses the suspension). Leaf springs are generally better at most significant square hits (dropping into a pothole, coming off of a curb). However, independent suspension is always better at side hits (think yaw or twisting, torsion) and is superior at maintaining control when turning. You can look up the data on scrub forces comparing independent vs. leaf suspension...you'll see that forces applied to the sidewall of the tire, frame twisting, etc. are fractional compared to the same vehicle with leaf spring suspension...especially with dual axles.
I have not found any objectively qualified data that proves independent suspension reduces structural wear on an RV. However, there is a lot of subjective data indicating this is the case and it much more than just anecdotal. My opinion, there are too many variables in RV construction to suggest reduced structural wear is an absolute beyond wear caused by yaw forces. But, we could look at similar rigs used in similar ways to draw some pretty good inferences.
I added IS and DBs to my 340RL that is being built. Here is a chart to consider. I had it labeled with what I thought were pros and cons but will leave that up to you all to decide as the "wins" were for my wife and me and the way we are going to use the rig.
Feature / FactorLeaf Spring with EqualizerIndependent Suspension
Weight EqualizationGood at equalizing load between axles due to mechanical linkage using the equalizerNo physical load sharing; each axle bears its own load independently
Ride QualityRougher ride, more vibration transmitted to the frame and contentsSmoother ride, less shock transferred to RV and cargo
Handling on Uneven Roads
(not applicable offroad)
May bounce or transfer impact between axlesEach wheel reacts independently, providing better stability and control
Component WearBushings, shackles, and equalizer parts wear out and need maintenanceFewer moving parts (in some designs), generally lower wear if properly loaded
MaintenanceHigher; requires frequent inspection of bushings, bolts, and equalizersLower for high-quality systems, but some may still require lubrication or inspection
CostLower upfront costHigher initial cost
Installation ComplexityEasier, especially for standard trailers More complex; may require welding or modification in aftermarket installs
Load Sensitivity More forgiving to slight loading imbalancesSensitive to uneven loading; overloaded axle can wear faster
Aftermarket SupportWidespread support, easy to find partsLimited to specific manufacturers and installers (e.g., MORryde IS, Timbren)
Ground Clearance & TravelLimited vertical travel; potential for “hopping” over bumpsMore vertical travel, better ground handling, will not hop when used within operating limits
Alignment OptionsFixed geometry, limited adjustabilitySome, i think all new systems, allow for alignment tuning and adjustments
Installation ComplexityEasier, especially for standard trailersMore complex; may require welding or modification in aftermarket installs
Load SensitivityMore forgiving to slight loading imbalancesSensitive to uneven loading; overloaded axle can wear faster
Nice write up. Informative and very objective. Gave me a few things to think about when considering suspension systems
Another benifit is you move to 8k vs 7k axel.
Yup! And we travel light so the extra beefiness is a welcome bonus for durability. Someone posted on Facebook that the GVWR goes up to ~19k with the IS and DB on the 2025 340RL. I cannot wait to get this rig!
Yep...ours moved to 19k on our 2023 340RL
treecatt
I have a 2023 Paradigm 310RL. I am travelling to Grant's Pass, OR the week before Thanksgiving to have the IS with disc brakes installed by Henderson's Lineup. My tow vehicle is a 2024 F350 Lariat. Anybody have a suggestion on what gain I should set the brake controller to after it is installed? I am currently set to a gain of 7.0.
You will likely need to determine this after you get hooked up and perform some low speed brake testing in the parking lot. Don’t forget that you will likey need to change a setting on your truck as well, your likely are set to electric, and will need to move to electric over hydraulic.
We have a 310 RL with disc’s(not IS), they really work well! We pull with a Ram, set at 6.5 if I remember correctly and the Heavy Electric over Hydraulic.
On my 340RL, towing with the same vehicle as you (CC, SB, 6.7L, 12K GVWR, stock tires, Bilstein suspension) 9 was too heavy, 5 was too light, and I settled in at 7.5.
On our 340RL (factory IS and disc brakes) and towing with a 2022 F-450 I have the brake set to 5.5.
@M and E ....any chance you didn't change brake controller setting to "Electric over Hydraulic" and that is why you're at 7.5??
Nope. All buttoned up. That said, they are replacing the brake pads under warranty as they are screaming.
Mike
@BryanValRox: Thanks for your info. I am aware of the settings that need to be changed. Just looking for guidance on decent starting values.
Need to make a correction , I double check my truck setting today and while I am on Heavy electric over hydraulic, my gain is set to 4.5 NOT 6.5 that I previously referenced. My Bad! Apologies for the error.
