HarveyTheRV
I have a 2021 310RL and would like to find out the wheel bearings and seal part numbers if possible to carry a spare set for our Alaska trip. Thanks in advance.
Thank you JimHere's a link to Dexter's website with the bearing info: https://www.dexteraxle.com/results/69/bearings-seals?SortOrder=Default
Not sure, but do you have a removable cap on your decorative wheel hub. If you do, you could remove it and see if you see a rubber plug installed in the hub itself. If you do, remove the rubber plug to access the grease fitting and lube away!Does anyone know if the 2024 32RLS has EZ Lube Dexter feature?
This was my experience with our 2024 310 RL as well.I added grease to my 310 today. For those who lubed their hubs for the first time did it take a lot of grease? I used 2 tubes of grease total for both axles just to get grease to push out around the bearings. I wasn’t trying to flush out the grease, just get some grease to push out. I had the metal grease caps removed during this.
The factory must not add grease to the spindle zerk fittings, just pack the bearings and call it good?
Yes, the factory install is to just pack the bearings ,which actually is good as it’s the bearings that need the grease to properly function. All of that extra grease pumped into the void space between the bearings is pretty much wasted aside from the little bit that oozes out at the front bearing during the pumping.I added grease to my 310 today. For those who lubed their hubs for the first time did it take a lot of grease? I used 2 tubes of grease total for both axles just to get grease to push out around the bearings. I wasn’t trying to flush out the grease, just get some grease to push out. I had the metal grease caps removed during this.
I don’t understand the last part of your post, but the tire needs to be off the ground to add grease via the EZ Lube fitting on the end of the spindle, you have to rotate the tire while pumping in the grease.If your fitting will not take grease...take some weight off the tire with your leveling system and the fitting should take grease fine. Ask me how I know. I was almost ready to change the engine, when checking the fuse first...LOL
