Rear wall movement damage to skirt metal
RockingRK
Putting this under "Frame" as I cannot find a better match.
Has anyone experienced this situation as shown in the attached pictures? No, I did not hit anything, this is from something inside pushing out through the skin. I have submitted to customer service.
Leo
Hello,
I have a similar problem on back left panel on a 340RL.
Panel has just pushed out. Have not hit anything. Panel pushed out while driving.
RockingRK
Suggest you contact customer service. This is a known problem and should be covered under warranty. Alliance working to repair mine.
Leo
Are both of yours the 340RL’s? We just ordered one!
Mine is a 340RL. I would check with Alliance to determine if they have modified new builds to fix this problem.
We have had our unit since Feb 22 and problem only surfaced after warranty was out as this is not considered a "frame" issue and covered under 3 year Frame warranty. Alliance service sent me an instruction on how to fix the problem. Parts were not expensive (128.00), but may require a shop call to get fixed, so probably $1000 total after all is said and done!
The Fowler's
We have a 2022 390 MP. Discovered it today after a trip from WY to CO. I've had too many issues with our Paradigm to be super happy with it. This was our first RV. Is this common throughout the industry? Also, the cover underneath it is coming of at the rear trailing wires behind us. I tried tacking it back up with self tapping screws and washers but that hasn't solved it.
RockingRK
Submit this to Alliance for warranty repair. They paid to fix ours. The fix also solves the underbody problem at the rear. We had that same issue as a result of the floor shifting. This appears to be common to any Paradigm with a rear couch. An Alliance design issue that is not across the entire industry (my opinion). Because of inadequate fasteners at the rear under the couch, the entire floor is allowed to shift which causes the damage. I have attached the repair process that Alliance provided to me. Repair done by mobile tech (found a great one here in Pensacola, that's him in the "after" picture finishing up the repair). Alliance will provide the skirting, the other parts can be obtained at a local hardware store. Also attached is a before and after picture.
  • Rear Wall-Floor Repair Process.pdf
Mike S.
Hi,
I have a 2021 340RL that has a damaged skirt at the rear, drivers side. This occurred 1 month ago while driving down the highway, I have not hit anything. My 1 year manufacturers warranty has expired, but my dealer is going to try and fight with Alliance to get this repaired. My concern is that unless an improvement has been made, this will happen again after being repaired.2984BD7A-D037-4F69-B4C4-19E42E6F5FE3.jpeg
dhcolesj
I hope this works out with Alliance.
This is beginning to sound like something that should be a recall. This could do a lot of damage and is definitely a manufacturing defect.
Sent from my SM-G781U using Tapatalk
The Fowler's
The problem is the self tapping screws holding the wall on are backing out.
Here are the instructions they sent me.
RockingRK
This should be covered under the 3 year structural warranty. Definitely a structure problem. Poor design and I agree this should be a recall. The fix is very robust and, when completed according to the instructions, should be a permanent fix. Should have been addressed at the factory.
Leo
My 340RL had same problem and since it was over one year Alliance refused to honor under warranty.
I ordered a piece of skirt material (128.00 for skirt and 180.00 freight) and received instructions on how to repair wall behind couch. Alliance sent me instructions.
Put larger screws in wall and went between screws with rivets.
It had also torn the underbelly material at back so repaired with tape and added a 1” by 1/8x8ft piece of aluminum to seal.
I spent all one day, but quote from Rv shop was over 1000.00 just for labor.
I am very disappointed in Alliance not honoring the 3 year structural warranty for this issue as it is definitely part of structure that failed.
I guess there words are cheap when it come to warranty.
PS. All screws in wall behind couch had come out wall and we’re laying behind couch, so check by unscrewing couch from floor and check wall fasteners
