Checked battery bank with multimeter showed over 13 voltsCannot find in manual how to clear code. It was fine yesterday showing everything. Tried disconnecting at box and it did nothing. Error code in book show no error but I have no other readings. Checked battery state in panel and it showed good![]()
Unfortunately, it appears your image doesn’t show on this end.Cannot find in manual how to clear code. It was fine yesterday showing everything. Tried disconnecting at box and it did nothing. Error code in book show no error but I have no other readings. Checked battery state in panel and it showed good![]()
Bryan I don’t know if moved some wires when I cleaned up hydraulic fluid that leaked around every fitting on top of hydraulic pump. I put a the tester on pv connection and showed 36 v if I did it right. The wires are a mess in battery compartment so I don’t know if there is a fuse.Unfortunately, it appears your image doesn’t show on this end.
Is there any activity in the control at all? Lights maybe?
Is there any chance, someone has disconnect wires recently and miswired it? Could the polarity be reversed somewhere?
Does the battery to controller circuit have any fuse protection in it that could be blown?
I turned off the solar and battery switch not at box. Could I disconnect wires at screws on front of terminal to try reset rather dig around battery? I did not disconnect any wires earlier. I am not very experienced with electricity.Bryan I don’t know if moved some wires when I cleaned up hydraulic fluid that leaked around every fitting on top of hydraulic pump. I put a the tester on pv connection and showed 36 v if I did it right. The wires are a mess in battery compartment so I don’t know if there is a fuse.
Can I ask for a picture of the wire connections on the bottom of the controller? It would seem that you have power given you have two lights on and the display is showing EO.Bryan I don’t know if moved some wires when I cleaned up hydraulic fluid that leaked around every fitting on top of hydraulic pump. I put a the tester on pv connection and showed 36 v if I did it right. The wires are a mess in battery compartment so I don’t know if there is a fuse.
I turned off the solar and battery switch not at box. Could I disconnect wires at screws on front of terminal to try reset rather dig around battery? I did not disconnect any wires earlier. I am not very experienced with electricity.maybe it happened 2 days ago as I did aurto hitch and re auto level. To get rid of suction noises. Which has worked so far. .it happened after that
Have you tried arrowing down to see if the screen changes values?I turned off the solar and battery switch not at box. Could I disconnect wires at screws on front of terminal to try reset rather dig around battery? I did not disconnect any wires earlier. I am not very experienced with electricity.
Would you happen to have the blue tooth app? If so, could you share photos of the screens and settings?
Did you check the buttons to ensure none are stuck down?
Do you have the manual?I pressed and held enter button and this showed up
Keep pressing the down arrow and see what happens, you are now on the setting screenI pressed and held enter button and this showed up
It feels like you are in the settings and troubleshooting mode and that is why your display is not active.I pressed and held enter button and this showed up
I really don’t think anything is wrong with your display. Read thru the manual, the sections on settings and troubleshooting should get you back on track.Now I don’t know which is right setting for the battery as I arrow up down I get battery symbol
That is set for lithium batteries. The LI in the lower rh cornerThis is what shows then goes back to E0 screen after 1 minute
What type of battery do you have?I have the manual with me but it is kind of hard to understand
