Yes the simplest way to correct the problem is to connect to a high pressure tank via the RV's High pressure tank or separate portable tank
There are extended stay fittings that allow you can to connect to the RV tank very easily and it is the simplest way to connect your grill to the RV.
However I prefer to connect to the quick connect on the RV. This may require installing a separate demand regulator or simply it becomes more complicated to do this.
Nevertheless I have been able to connect my when generated to the RV quick connect but I had to add a demand regulator. It took a few fittings and adapters and more trial and error to accomplish this. A quick easy solution is extend a stay. A more complicated solution is connecting via the Quick Connect.. Once you have it all sorted out, quick connect is more convenient, However most direct and easiest solution is to use an extend a stay and connect to the RV propane tanks.
