From the factory, when the 29RL is level, it sits too low for late model HD (3/4 ton and up) trucks. This varies a bit by brand and model of truck but I don’t believe that you’ll find one that sits low enough for the 29RL. Possible solutions (may require a combination of these): raise the pin box as high as proper tailgate clearance will allow, lower the hitch as low as the hitch and tailgate clearance will allow, install lift blocks between the axles and springs, install taller tires and wheels (17 1/2” wheels are one option) or fabricate and install a custom suspension subframe. This is something that Alliance really needs to address. I suspect they designed it this way because the height pairs nicely with a 1/2 ton truck, but I’m not towing it with a 1/2 ton - you do you. I have a 2025 29RL that I tow with a 2026 Chevy 3500HD SRW. I’ve raised the pin box, lowered the hitch and installed 2” lift blocks and it’s still nose high. I’ve decided to live with it at this point
