Two on the road
Does anyone know how long the dull 12v batteries that come with my new 340rl last to power the Norco refrigerator only.
Did you upgrade to the Super Solar package? If not, it will be up to your dealer to install a battery and you can only guess that will be a low quality battery. I'd swap out for 200 amp hours of Lithium. We will have 810 amp hours of Battle Born batteries (3x270) in ours with 2000w of solar on the roof. We boondock most of the time, so we need this type of a setup.Does anyone know how long the dull 12v batteries that come with my new 340rl last to power the Norco refrigerator only.
Note...I do NOT have my 340RL yet...this is all a speculation from me at this pointThe unit came with the standard system. If I was to leave the unit unplugged for a day or two are the existing two batteries, how long would they last powering only the 12 V Norco refrigerator
Put the morryde on. Took off the roto flex pin box. And sumos on the trailer . That roto flex doesn't work well for all 5th wheel hitches. My hitch moves front and back, and side by side. Morryde has 3inchs of movement and 1.5 inches of side movement. This is the best towing I ever had with a 5th wheel. Had 5th wheel trailers since 2008.We are getting our 340RL just before the rally, so love to hear back from you on which way you finally decide on.![]()
We have arranged to have the MorRyde RPB installed at the Rally.Put the morryde on. Took off the roto flex pin box. And sumos on the trailer . That roto flex doesn't work well for all 5th wheel hitches. My hitch moves front and back, and side by side. Morryde has 3inchs of movement and 1.5 inches of side movement. This is the best towing I ever had with a 5th wheel. Had 5th wheel trailers since 2008.
Did you buy and install yourself? What did Gen-Y say about the issue?We have just changed out our Roto flex to a GENY hitch on a 340 RL. The biggest problem we have is the 340 RL sits a lot lower on the nose so the GENY hitch makes the trailer sit too high in the front and too low in the rear. We have lowered the BW companion hitch as low as possible, and raise the hitch on the trailer all the way to the top of the rhino box.
Has anyone had a similar problem.
Thank you for the info, Would you have the part #We have arranged to have the MorRyde RPB installed at the Rally.![]()
I HAD TO DRILL NEW HOLES IN REAR 4 BOLTS. THE MORRYDE IS ABOUT 4 INCHES LONGER TOWARDS THE FRONT. WHICH GIVE MORE SPACE BETWEEN TRUCK AND TRAILER .Thank you for the info, Would you have the part #
Our 340RL should have (we pick it up May 23rd) a Rhino pin box (confirmed with Alliance) so we are ordering the "RPB77-FD-05" and MorRyde will install at the Rally. Link to chart below....Thank you for the info, Would you have the part #
My morryde is the 1621hd from my previous 5th wheel so ,I used that. Great that have one that works.Our 340RL should have (we pick it up May 23rd) a Rhino pin box (confirmed with Alliance) so we are ordering the "RPB77-FD-05" and MorRyde will install at the Rally. Link to chart below....
My measurement is 12.750 from cap to flat plate on pinbox.My morryde is the 1621hd from my previous 5th wheel so ,I used that. Great that have one that works.
NICE....another Oregonian with a 340RLI just towed a 340RL from Oregon to Phoenix with my 2015 GMC 3500 SRW. I have the Pullrite Superglide 4400 and the trailer tracked perfectly and no sway at all.
Are you talking about the Gen-y gooseneck hitch? I currently have a autoslide hitch and was thinking about changing to a gooseneck. If you are how do you like the hitch. I will be towing with a short bed truck but I’m concerned about clearance when turning tight. I have a 2023 340rl.Did you buy and install yourself? What did Gen-Y say about the issue?
