rvdude
I know that there are NO perfect rv's, even with the super expensive trailers and motorhomes. But everything I had heard about Alliance quality before I purchased one doesn't seem to be that they are any better than the rest of them. This trailer was purchased July 21, 2026 (252RL) I love the trailer layout and will be glad to get all the kinks worked out. My list...
1. Backsplash is very loose and has a large pocket of air behind it (I've seen several posts about this on the forum). It was this way at the dealer when looking.
2. Both bed struts came loose from the 1/4" plywood and the 1/4" little squares ripped off of the plywood. (I've seen several posts about this on the forum).
3. Electrical problems--had a bad main breaker. It has been replaced. The breakers were mislabeled in the breaker box. That has been done. The converter trips periodically. There is no inverter but the 2 inverter breakers have to be off or the main breaker will trip as well as my 50 amp supply.
4. On the 2nd trip, the shade under the TV came loose. I had to fix that last week while I was out with the trailer.
5. On the 2nd trip, the bedroom sliding door came loose at one end. (I've seen many posts about this on the forum).
6. On the 2nd trip, the microwave door will not open. It has only been used once. (I've seen many posts about this on the forum). I know that Alliance does not make the microwave, but maybe with all the problems they should use a different vendor to supply them.
7. The cable tv (for the rv park cable) does not work.
All of this on a 2 month old trailer that has only been out on 2 fairly short trips. I sure hope it will get better. I have 2 trips planned in October, 1 in November, and 2 in December... if it's not in the shop all this time.
