Pretty excited to pick up our new 252RL 2 weeks ago. Generally very happy with it. However, there a few problems that need fixing. Discovered these issues when at home getting ready for first trip out. Strike plate for rear door latch screw stripped. Plate won’t remain in position. Unable to engage latch and door won’t close. Screw dropped on floor bound under trim strip for slide out, pulling the trim out. Slide out flooring pulled up at one end refuses to lay flat. Tripping on it. Awning motor failed after 3 uses and awning won’t retract. Screw holding heater exhaust half way in and cross threaded. Wiring harness for something hanging out 2 inches and caught between frame and flooring. Won’t know what that wiring is until something fails. Smoke alarm is so sensitive we cannot make a cup of coffee without it going off. Had to remove battery to cook anything. These are all nuisance items but they reflect sloppy workmanship on the part of individuals at the Alliance factory. Now I am worried about what other and more serious problems exist I cannot see yet. Maybe the water tank will fall out? Dealer happy to fix in 6 weeks. Two trips planned where we will have to deal with these headaches. Seems like this sort of stuff should be communicated to Alliance. Much of what I read suggests this is usual and customary with new RV of any manufacturer. What do you think? Presumably the dealer will review with Alliance.
