We had general do it before we took delivery. They were running a special. I believe it was about $2500 for all 3 installed. Probably cheaper to have them done aftermarket. Nice Rig. we have the same thing.what's the ball park cost for these? we have a2024 Avenue 32RLS with the custom paint. was thinking about doing this for all 3 slides. thanks
thanks looking into it nowWe had general do it before we took delivery. They were running a special. I believe it was about $2500 for all 3 installed. Probably cheaper to have them done aftermarket. Nice Rig. we have the same thing.
I am not sure if Alliance installs all 5 of the screws on the mounting bracket....most MFG's will only put in 2 of the 5. Then it is up to the installer to install the remaining 3 screws.Ok Mr Jim, you got me on that detail. The brackets were installed at the factory & the toppers were installed by the dealer. The point is the brackets were installed with screws which seems to me to be a poor practice given the tension generated when the slide is opened & what happened to us as a result.
Unless the process has changed, there is only 1 set (2 screws) used. Trying to add the other 2 will do nothing as the bracket is not lined up with the mounting plate. It is designed to only us 2 screws based on the height of the plate.On my 29RL the #2 bracket where where motor mounts is where the bracket needed the 2nd set screw installed.
