Slide Topper Attachment
Meanjean73
Shame on me for not inspecting this but the tech found this yesterday when he was working on the slide. Manufacturing issue, I should have found it, but it’s getting fixed now.
https://share.openphoneapi.com/v1/file/i/de1692f5-000c-4070-8f80-e02c48d846ca.qt
Don’t feel too bad. I thought I did good on my PDI but missed a few things too.
Is it the outer bracket or the factory bracket bolted on the slide? It looks like they didn’t slide the two together properly. Should t wiggle like that if the two are mated correctly
Honestly, I’m unsure. I was super busy yesterday and had to leave the tech with the rig and that’s when he found it.
You remember the name of those rivets? They have the 3 legs that expand correct? I found these?
Amazon rivets
Hi - did you wind up using the rivets instead of screws? If so, how are they working?
We had Lippert Solera slide toppers installed at purchase by General RV. Worked fine until we had an issue last year camping in Maine. Kitchen slide topper ripped right out of the RV side and got mangled. Finally decided to replace it this weekend. Only 2 screws were in something solid. The rest just spin. The holes in the RV side bracket for the new Lippert Solera don't line up with the old holes and aren't hitting anything solid either.
Add insult to injury, I looked at the dining room slide topper for reference and it was pulling out of the RV exterior now. I was able to remove every screw using only my fingers and a screwdriver bit I think the only thing holding the bracket to the RV was the dollops of silicone behind the bracket at every screw.
Jwtsg
Good morning! We did use the rivets on a 12’ slideout awning on a previous travel trailer we had,,similar exterior wall construction,,,our trailer at that time was a Venture Sporttrek touring model 38’ tow behind,,,,,was recommended by that mfgr service dept. used large head “mushroom” pre slotted shaft rivets that provided a 3 or 4 point “ collapse. Don’t recall brand but they held for 6 years on our travel trailer over probably 10-12k miles w no adverse impacts,,,‘‘this forum has threads that discuss & id the recommended rivets,,,they have engineering data for the various sizes,,,also know that you tube has videos of the repair steps & products,,,,,there Are opinions on screw vs rivet solutions in this forums threads that have good points,,,other members may have input as well,,,,was not a difficult repair & worked very well for us cuz we were out of warranty,,,👍🌞🍀 good luck!
