HarveyTheRV
Can anyone suggest how to get the top slide flap seals to flip out when the slides open. They are conditioned and in good shape but most times will not flip to the out position when the slide is extended.
I looked on Etrailer and didn't see anything? I sent an email to Alliance, see what they have to say.It may still be worth touching base with Alliance. They may send some your way regardless of the warranty. I think e-trailer has something similar for purchase.
My tops flip out 99 % of time. When I setup I take ladder and look. Only the big driver slide has been problematic on same slide. It has flippers on side but still front left top doesn’t flip out most of time.Hi there!
Sure can, this is an easy one. Install a seal flipper(technical term I know)! So, our 310RL has thin pieces of plastic or rubber installed on both sides of our kitchen slide out. The concept is that because there are no windows on either side, there is no molding that has to travel under the seal to start the flipping process.
You certainly could do the same for your top seal. You will need to figure out optimal placement so that it works in both directions, but if you get something that has to travel under the seal, it should catch and starting the flipping process until friction can take it the rest of the way.
I would contact Alliance and ask what they use and see if they will sell you some.
Yeah, I normally had issues with at least part of each of the top seals not flipping during set up. I to would get the ladder out and check and correct them via a extension pole under the back side to get them flipped out.My tops flip out 99 % of time. When I setup I take ladder and look. Only the big driver slide has been problematic on same slide. It has flippers on side but still front left top doesn’t flip out most of time.
Any idea where to get these besides Alliance? No warranty on mine and I could use some for the kitchen slide.
Found this, maybe it would work?
Amazon Trim
So Alliance has specific material listed as slide flipper material within their parts system. It doesn’t look quite as thick as what you have installed.I bought these off Amazon and after installing 3, 16” sections on each side thought it may be too much? Clearance on one side is tighter than the other. Slide room is not perfectly centered.
Not sure what Alliance recommends?
Also, some pictures online shows them at a 45 degree angle. I went vertical, is that bad or cause too much drag on the seals? The main location for the seal to stay tucked was in the center.
The seals flip with my test run. I can tell they are putting some tension on the slide out. Just a sense it’s working harder to pull the slide in.So Alliance has specific material listed as slide flipper material within their parts system. It doesn’t look quite as thick as what you have installed.
After looking at your picture, if you continue to have issues with the seals flipping fully, I would recommend that you relocate the flipper. My recommendation would be a bit more centered on the slide width. The theory being have the flipper run under the seal sooner and let friction do the rest as the slide extends. We never had a problem with our kitchen slide side seal with the factory placement of the flipper.
I took the same approach and installed flippers on the top of all three slides and haven’t had an incomplete flipping event since the install.
Where did you get your flippers?Not sure what you mean here. If it is on your hydraulic slide it should care. I know on mine the left and right on my kitchen slide hand to be recentered because it had a lot of room on one side and was super close on the other Struggled getting a finger in on one side. This also fixed the seal flipping issue I was have on the sides of this slide.
Also my slides and landing gear got faster when I changed out the auto reset breaker for an 80amp and upped the wire side.
The top of my slides are getting flippers this year. I have noticed they have issues flipping on overnight stops at first, but flip good after I have had it set up for a couple of day. Think it is just seal memory, it is a long seal. Seems like cooler weather also affects the flip.
It seemed like the slide had to work harder to pull in.Not sure what you mean here. If it is on your hydraulic slide it should care.
