Slide out seperation?
Recently adjusted our LR slideout, 2022 Paradigm 340RL. About 3/8" outward adjustment, to try and get floor out farther and reduce height at the interface. After arriving at next stop I told my wife I wanted to watch the slide operate, especially the end near the door. I stuck my head inside as I noticed some excessive movement (I thought) in the ski I just reinstalled. That is when I saw a gap between the floor and the side wall of the slide out, prob about 3/8", at the interior end. Went ahead and had my wife run the slide out, as I went from inside to out to monitor. The gap closed up, but it seems obvious the end wall is pulling loose at the bottom. Any ideas on what causing, and how to fix?
One pic shows the flooring pulling out from under the end wall. The others are to show resulting clearances with slide fully extended, and the location of the floor edge of the slide out.
GriffLab
Poor design, poor construction. Not sure. Here’s a pic of our 2023 310RL. Been on 3 total camping trips. At the dealer now we will see how it’s resolved. Right now. Very disappointed.
GriffLab
Hi Bikin',
Alliance and our dealer have been very receptive and quick acting to our issues. We are very experienced RVers and have realistic expectations concerning these rigs. For the money we spend I expect to not have these initial issues from a "High End, Luxury" fifth wheel.
We really do love everything our 310 offers and hope this ends our problems.
Take Care and Safe Travels,
Rawn
Still waiting on photos from the dealer but after one camping trip, among many other problems, our 37MBR has a "stress crack" on the kitchen slide. I'm told they need to bring out a welder and painter to fix. More disturbing, they claim they've seen 3 other Alliances with the same problem.
GriffLab
Follow up:
Wanted to be fair and give some info on how things turned out. The dealer addressed all our issues in a timely manner. We are on our first trip since repairs and all is well. Props to Alliance and our dealer for nice work!
Follow up:
Thanks for following up....great to hear things were taken care of. :)
@Likin' Bikin' - I am not qualified to speak to your slide issue, sorry about that. But I did see on the black plastic wear bar, that one of those screw heads is proud of the top of the wear bar. Best to remove it, countersink the hole, the put the screw back.
I learned the hard way that screw heads proud of the wear bar will tear the slide floor bottom up real good.
The more I read, the more I find on my unit, the more I feel that I traded one bucket of …. for more of the same. I believe I have taken it out 3 times for maybe 350miles total, and been at dealer twice….still there this time for 3-1/2 weeks. I will certainly keep an eye on the slides for sure.
Followteambs
Any pics of yours?
any pics of yours? What year valor?
I actually looked closer at the picture and ours isn’t doing exactly the same thing, ours is actually not fully extending but I don’t see this same issue. We have a 2021. I’ll post a pic of what ours is doing when I get back to it.
Knuth123
I had issues with the front not fully extending and then seemed to suck too far in.
I had to adjust the front track so it extended and retracted evenly.
As far as my skid ski splitting apart. I bought updated ski's from Alliance. However I'm not sure I like the updated style. I believe I'm gonna buy the rec-pro set, as I like the taped front better.
Knuth123
Follow up:
Do you happen to know how or if they attached the floor to the slide wall frame before they replaced the ski?
Knuth123
I finally got around to tackling the slide ski issue. Got worse as I dug into it.
Originally started with the floor dropping from the wall inside. Then the ski broke apart and really allowed the floor to drop with the slide in. Removed the old ski and trim to replace with the updated slide ski from alliance and found the floor was rotten and the screws pulled through the floor placing all the stress on the ski when the slide was in or moved in and out breaking the ski.
My unit is supposed to go in August 26th for a side wall crack and possible frame flex issue. I'm now going to add this slide floor to the work.order and see if the 3 year structural warranty covers the replacement of it also.
In the mean time I have reattached the floor to the slide frame using larger #12x2" screws and installed the updated skis front and back. 1000005430.jpg1000005433.jpg1000005430.jpg1000005437.jpg
phfkef
I have a recentlypurchased 2022 Paradigm 310RL. Just completed our first camping trip. Had to pull over to shut and lock the small access door to the hydraulic leveler.
While doing that I opened the large storage door on the driver side. I found that i couldn't close it again. It was hitting the frame at the bottom. It doesnt do this when parked and sitting on its jacks. I immediately thought of frame flex so I came to this forum looking for how much flex to expect. I am concerned.
Shelly S
In the mean time I have reattached the floor to the slide frame using larger #12x2" screws and installed the updated skis front and back. View attachment 2213View attachment 2214View attachment 2213View attachment 2215
So what happen with getting the warranty to cover these issues?
