CThomp86760
I have a 2025 385FL equipped with the sn4 sanimarin toilet in the rear, and everything works, except it doesn't fill the bowl with water. I've done the (eco and full) button to max fill level, and re-zero the black tank on the panel (full and empty), yet the bowl dribbles at best with water. All wiring is correct on the brain underneath in the compartment, and you can feel the little motor pulse when you press the flush button. Is the little motor bad?
