Proper Truck to tow Alliance Avenue 32RLS
Sagi1971
I am in the process of looking into purchasing an Alliance Avenue 32RLS. I am in the VERY early stage of looking into it.
What I am curious to find out is this.
What particular truck is best for towing it?
exps01
It can depend on a lot of factors, but at a minimum I'd say a 3/4 ton truck like an F250 or 2500. It's very dependent on weight, truck size, bed length, single rear wheel (SRW) or dual rear wheel (DRW), etc. I have a Paradigm 310RL and have a 2020 GMC 3500HD with DRW with the long bed and diesel engine. My weight capacities are higher for payloads compared to a 2500 SRW. My experience so far has been great. The truck has no issue with towing, it's nice and stable, etc.
You could look at some YouTube videos on truck and trailer capacities. I know NRVTA, Big Truck Big RV, Keep Your Daydream, and many other channels have videos on this that I thought were very well put together and explained all that goes into "What truck is best". Irene Iron Travels is another who had a 3/4 ton truck with an Alliance Paradigm 310RL and found out they were overweight when they got on a scale. That's the big factor. Research the weight limits and payload capacities for each truck and the specific setups, because they can vary a lot, even with the same model depending on configurations.
Hopefully that's helpful info. Not a specific "get this truck" answer, but I don't think that's really out there unless you just want to get something that will automatically be overbuilt for that trailer, like an F450. Even then, if you load it with rocks, you might go overweight!
Turfengineer
We pull our 32rls with an F350 gas. It does really well with ~4K lbs of payload and plenty of power for this lighter trailer. I use a goosebox and offset ball in the 6’9” bed without issue.
TonyG109
I'm a little late to the show but for the benefit of others...
I picked up a 2025 32RLS in Sept '24. The unit is stock and has no additional features such as double pane windows, etc., (except for two full propane tanks and a lead acid battery that the dealer added) that would add additional weight. I weighed in just before picking up the unit and immediately after and I was a bit surprised at the results. Advertised pin weight is 2,000 lbs, actual was 2,460. Advertised dry empty weight was 10,500 lbs, actual was 11,180.
That's 460 extra pounds of pin weight and 680 extra pounds dry weight. Pin weight is usually the limiting factor when choosing a truck capable of handling a 5th wheel so the 460 extra pounds on the pin may be a bit of a concern to some.
In my case, I have a '23 RAM 3500 diesel SRW. I can have 7000 lbs on the drive axle. With the 32RLS hitched up, I have 6220 lbs sitting on the drive axle. This only leaves 780 lbs. left on the drive axle before I'm overweight. Add fresh water, some solar equipment and all the other necessary gear (in the unit and truck) and I'll be getting close to the limit, if not exceeding it.
I don't know the carrying capacity of different trucks but I would venture to say that many 3/4 ton trucks, especially if it has a heavy diesel engine, will be cutting it close or possibly exceeding the recommended weight limits for that vehicle if pulling a 32RLS. I'd be interested in hearing from 3/4 ton truck owners who have weighed their trucks on where they stand, especially gas trucks since they will probably have a higher weight carrying capacity.
So I guess the takeaway of this is to choose your truck carefully and to take the advertised weights of your 5th wheel with a grain of salt.
This is why experienced RV'ers know to ignore dry weights. They are notoriously inaccurate and deceiving.
All calculations should be done using GVW or the RV. Pin weight estimated at 22% of GVW.
Now some argue GVW is overkill and they will never load RV to max. GVW.
If we assume that is true worst case is you end up with a bit too much truck.
Too much truck gives you a bit more margin above your parameters which is generally a good thing in terms of performance.
However if you use dry weight worst case is you end up with the wrong truck.
If you Exceed axle rating you have the wrong truck.
More capacity margin is a good thing, there is no need to cut it close.
Using GVW eliminates the surprises encountered when using dry weights.
TonyG109
If you Exceed axle rating yu have the wrong truck.
Using the 22% rule seems to be a good rule of thumb.
Exceeding the axle rating on any truck is definitely a bad idea when towing an RV since we're usually traveling a long distance. The wear and tear may show itself in a most unpleasant, expensive and possibly dangerous way. To me, it's not worth the risk.
Interesting. It looks like they've removed that resource.
Same result. 2 year old thread anyhow.
@Flyer32RLS It works in a fashion. For me it only brings up the Alliance main page.
No link to Tech-Tip-Can-My-Truck-Tow-This.pdf
It looks like Jim Beletti posted it — maybe he still has it but it would be >2 years old.
In a search bar this does not find it either...
site:alliancerv.com "Tech-Tip-Can-My-Truck-Tow-This"
Campmac
Hello. I'm looking at buying a 32RLS as well. I will tow with a 2026 GMC 2500 Duramax 6'8" bed SRW with the Max Trailering Package, which basically means it is built just like a 3500. I am not seeking input on weights, but I would love to know real world experience from a clearance standpoint with a late model GMC 6'8" bed and 32RLS. GMC places the puck hitch system in the bed a little further to the rear than others, and I think that helps. I would like to avoid a slider. I am also thinking of using a Reese Goosebox and would appreciate any input on that.
OK no inputs on weight as requested.
I would only suggest you look at the Anderson Hitch. 35LBS and takes 5 minutes to install or remove. Had a F250 65'8" bed and no problem with the Anderson on clearance with rail or rear window.
Campmac
Thanks for the feedback Flyer. That's encouraging that you had acceptable clearance without a slider. I guess the layout could be a little different between the Ford and GMC, but I think the GMC puck system in my truck may be a touch to the rear of the Ford. The center pin is a few inches rear of the axle. I have not looked at the Anderson hitch. 35 lbs. is certainly is easy enough I guess. I just don't want the hitch in the truck unless I need it - I use the bed for lots of other things. I will check out the Anderson.
Thanks again.
