Campmac, it is extremely easy and light weight. Those B&W hitches and ones like them puch 250 LBS. I've read some people have an A frame that they can take it out of their truck with. Anderson is super easy and light weight. If you need your bed when not hauling, you couldn't beat the Anderson for space3. If you purchase make sure you get the 3.0 version. Its a beefed up version of aircraft aluminum, 24,000lbs tow capacity.I just don't want the hitch in the truck unless I need it - I use the bed for lots of other things. I will check out the Anderson.
I also have the Andersen version 3 and could not be happier with it. Just be sure to lock the coupler after you lower it on the ball! It’s not automatic like some of the 5th wheel hitches are.Campmac, it is extremely easy and light weight. Those B&W hitches and ones like them puch 250 LBS. I've read some people have an A frame that they can take it out of their truck with. Anderson is super easy and light weight. If you need your bed when not hauling, you couldn't beat the Anderson for space3. If you purchase make sure you get the 3.0 version. Its a beefed up version of aircraft aluminum, 24,000lbs tow capacity.
UGA, I agree, I usually stand back and take a look. Hitch locker, check, safety chains on, check, eletrical connections made, check.I also have the Andersen version 3 and could not be happier with it. Just be sure to lock the coupler after you lower it on the ball! It’s not automatic like some of the 5th wheel hitches are.
