ML226 - Shower Skylight - cover
kmsimm25
We use those popular 14 x 14 reflective pillow covers for our bathroom fan to keep the light / heat out. Works great! The shower skylight is 14 x 28ish. Wondering if anyone has found a cover that works in this area (other than putting 2 together and using Velcro to keep from falling). Thanks!
We have considered adding insulation, styrofoam or something else inside the skylight between the inner and outer cover to block the light.
When a friend of ours had his roof sprayed he just had them spray over the skylight.
I know it's standard and expected on EVERY RV but I'd just as soon not have skylights. The first one of us to get up in the night closes the bath door.
jagibson58
Something we applied on our last two RV’s and now our Paradigm 310RL, we applied a plastic type material to the inside of the bathroom skylight. Very easy to apply with minimal water. The material can be applied on a flat or curved surface. Purchased ours at Lowe’s. Differing designs available. Picture attached.
Skylight consist of an outer glass on the roof and the inner glass that is held in place on the ceiling with a plastic frame and screws. It does minimize the light coming through the skylight and some heat.
