Main Room Can Lights
Top942002
2026 Paradigm 340RL main room ceiling lights do not repond to switch/dimmer inside doorway. All fuses check good. 12v fuse panel position #4 LED doesn't light when fuse pulled. Are the main room lights on zone 4? Any thoughts are welcome for troubleshooting.
While I am unable to answer your direct question, have you tried pulling the light switch from the wall to see if you have power to the switch. And if so, jumping the two switch wires together to see if they light up?
Also, remember it take a ground connection to compete the circuit, so if that is missing the result would be a no light condition as well.
A meter or test light would be helpful to perform tests to help narrow your issue down.
Great advice as usual!!!
