Gord&Cindy
If you have room, one 200Ah is better and easier than 2 100Ah.some of my boondocking and winter storage will have temps in the mid 20s
with lithium will i need units with built in battery heaters
any thoughts on two 100 in parallel versus a single 200 unit i have two gen sets so charging is not a problem
thanks
Check to make sure the battery has a low temp cut off for the charge and discharge. That will protect the battery in the cold. You don't necessarily need a heated battery unless the battery will be getting really cold (the battery should tell you what temp it can charge/discharge at). Also, remember it's the temp of the battery, not the outside air temp, that's important.
