It all depends on your own situation.
1. My TV doesn't provide power when the ignition is off. Also, many modem trucks have a diode to prevent backfeeding from the trailer to the truck.
2. My truck can put out as much as 14.8v if needed and the alternator is controlled by the computer. I have 10g wire and a 30-anp fuse, so I can get power to the battery if needed.
3. Yes, you can get higher current, potentially, using a DC-DC charger. The key you are getting wrong here is that LFP will absorb what a charger can throw at it. It does not actually control anything about the charging process from the supply side though.
4. These can all be a problem during inclement weather or traveling at night.
However, this only really helps a ton when you are driving a lot, and even then, only when your destination doesn't have power available. Otherwise, your batteries need to only hold you from pole to pole if that is the type of camping you do. And a cold refrigerator and freezer will stay that way for long periods of time if you are not opening the doors. What else would really drain your batteries while traveling?
Case in point, I have a 45' fifth wheel, residential refrigerator, and a bunch of low power drawer electronics in my trailer that I run off the inverter. Between my solar and my 7-pin, I can get up to about 25 amps of power into the batteries when the sun is shining while driving. I use about 10-15 amps of power through the inverter on average when traveling. And that is with running everything including the fridge. I am still netting about 10-15 amps of charge through all of that.
In my case, a DC-DC charger would not buy me anything really. Worst case - I have a Onan 5500 LP generator on board.
All that to say, sure, for some use cases a DC-DC makes sense, but for many, imo, solar is a better investment. DC-DC doesn't help much when you are boondocking. However, my solar can run about anything I need (coffee is harder but doable with a stove top percolator we have from tent camping) as long as the sun is shining and will keep my batteries topped up. If not, my batteries can hold for a few days with careful usage of the fridge and cycling even with low levels of sunlight.
I have 3x190w PV on the roof,a 30a PWM SCC, a 1500w pure sine inverter, and 2x100ah of LFP. I monitor usage with a Victron SmartShunt. My solar package was provided by the manufacturer and is GoPower oem equipment.
