Kitchen Sink Not Draining
divinIN
Hi Jim,
I'll find it here in a second. It was at Home Depot and while composing the response I couldn't find the one I used when searching online. I'll try again and if I still can't find it I'll head to the store and grab a photo. I literally live two minutes from Home Depot. That's a good and a bad thing for a man. ;)
divinIN
Here's the product I used and the link. I didn't find it before because I was looking for a picture with a brown fluid in it and the one online is greenish. I'm sure other similar products would work equally well, but this worked for us.
Good Day Everyone,
I have a 2021 390MP. The kitchen sink is not draining. My son and I spent a couple of hours last night trying to fix it. Here is what we have tried:
  1. Snaked sink several times.
  2. Snaked through bathroom sink.
  3. Snaked through shower. In this I did get some hair out but the shower was never the issue.
  4. Based on some info we found online we checked the roof vents. There are three. The furthest aft vent which comes out slightly forward and left of the middle AC unit looked like it had water way down in it - we could see the reflection and movement of the water when we used a flashlight.
I don't think seeing evidence of water is good, but not sure where the issue may be, especially after having snaked the lines several times with no evidence of blockage.
Any suggestions/ideas would be appreciated. Thank you everyone.
Try under the sink it has a ventless vent. It unscrews by hand and they do go bad. Has happened to us.
judymcadam
My problem is that the switch that drains the kitchen sink won't work. I changed the fuse but it didn't help. I cannot drain the sink. Alliance said just get new fuse... didn't help. It is a dumb idea anyway to have a switch to empty sink. A plug would work fine without have the macerator under it. My 5th wheel 2024 alliance I think is the only one that has this crazy contraption. I live in it so very inconvenient! Any ideas?
The kitchen sink drains into a separate independent grey tank on my 2022 390MP.
It has nothing to do with bathroom sink or shower.
Have you pulled the handle for the 2nd grey tank? 2nd handle is not on Nautilus panel. It is located on beam below the door to the
Nautilus panel. My unit has manual dump valves not electric.
