I'm not sure what the factory uses. If I was doing it, I would use construction adhesive, then use temporary wood supports to hold it in place while the adhesive cured, then add metal sink clips.Thanks for info will get pictures What kind of adhesive
Use 100 percent silicone. You can also fashion clip holders out of scrap solid surface and crazy fly them to the bottom of the countertop. Yea crazy glue! Acrylic lives crazy glueI'm not sure what the factory uses. If I was doing it, I would use construction adhesive, then use temporary wood supports to hold it in place while the adhesive cured, then add metal sink clips.
Note, this is just what I would do and not factory service advice. If you want that, kindly reach out to our team at service@alliancerv.com
Our sink fell down several times, glue will fail eventually. I bought this kit, then realized the innerds of the caninet wouldnt support it, so I added support boards and went ahead and beefed up the floor also. RView attachment 2776View attachment 2777View attachment 2778View attachment 2779
I put the Moryde on mineThis kind of thing wouldn't happen if manufacturers focused more on the suspension system than cutting costs. The roads, particularly the interstates are in terrible shape. Heavy trucks are destroying them as fast as they repair them. RVs need special suspensions with some kind of dampening, like shock absorbers, or something.
FactsNo doubt the roads are rough and rv suspensions could be improved
However undermount sinks fall, come loose in stix and brix houses.
It is a fairly common issue. Amazon sells a repair kit for undermount sinks.
Undermount sink repair brackets on Amazon
Alliance is now using Lippert’s new helix pin box and TCS suspension. You can see it in Matt's video.This kind of thing wouldn't happen if manufacturers focused more on the suspension system than cutting costs. The roads, particularly the interstates are in terrible shape. Heavy trucks are destroying them as fast as they repair them. RVs need special suspensions with some kind of dampening, like shock absorbers, or something.
