Hot water on demand conversion
Hi all
Just picked up our 2026 252RL, and overall we are very impressed with it. The fit and finish are outstanding, especially compared to our old unit. However, we are not a fan of the inefficient and wasteful tankless water heater system. Has anyone had the on demand system replaced with a traditional 6 gallon water tank?
2 Allies
Congratulations and Welcome to 'The Alliance '
No experience with swapping water heaters, others may help.
Enjoy,
Welcome.
I swapped out an on-demand for DSI on our last RV. Easy-Peasy if you have access to 15A of 120V.
I would even accept a propane only 6 gallon HWT with bypass, but would it mess with our extended warranty? If I had the stealership install it, would that make a difference?
I forgot one other piece of the puzzle... the on/off gas/elec controls. I replaced a panel inside the coach to add the electric switch. I don't know what the controls you have look like but you may need another cable run from the WH to a new two switch panel somewhere. No-one said you can't put that in the basement. 🤷🏼‍♂️
IMHO - a gas only WH would be somewhat inconvenient having to refill propane bottles more often.
My 310RL came with a Suburban Model SW12DEL (12 gallon tank). Before settling on only 6 gal you might check your rough opening to determine if a larger tank model will fit.
