Part of the gvwr is transfer weight to the tow vehicle. Is this on a 5er or bumper pull?What effect does having 2 - 6000 lb axles have on a rig with a UVW of 10,942 lb and GVWR of 13.995 lb? If I load to the cargo weight of 2993 lb, what does that do to the axles? Is the true cargo weight about 1,000 lb?
When I took my loaded 32RLS across the CATs Scales: I have 9,360 lbs of weight on the camper axles and the pin weight is 2,880 lbs. My 32RLS loaded weighs 12,240 lbs.thanks for the replies, trying to learn something here.
5th wheel (32RLS). The 2993 is bad math. I took GVWR-UWR or 13995-10942=3053
Since it is 60# even, maybe they are accounting for full propane tanks?thanks for the replies, trying to learn something here.
