richanddar
Has anyone had a problem putting fuel in there 5thwheel? I tried for the 1st time and the fuel after about 50 cents shot back out. And this happened on both sides of the fueling station.
This is either a issue with the fill line( assuming the fill neck is connected with a hose) or venting with the tank.Has anyone had a problem putting fuel in there 5thwheel? I tried for the 1st time and the fuel after about 50 cents shot back out. And this happened on both sides of the fueling station.
How is this investigation going? Have you found any issues with the fill neck and venting?I only fill with regular gas, these tanks are not compatible with diesel fuel, per the manufacturer.
