Fueling station
Has anyone had a problem putting fuel in there 5thwheel? I tried for the 1st time and the fuel after about 50 cents shot back out. And this happened on both sides of the fueling station.
I don't have a toy hauler but I have heard of this problem when adding fuel.
On our previous RV — a motorhome — the filler necks were almost horizontal and would burp diesel fuel if I wasn't careful. I would even use the leveling jacks sometimes to tilt the coach away from me. Seemed to help.
Search the forum and maybe there's an answer for you. Good luck.
This is either a issue with the fill line( assuming the fill neck is connected with a hose) or venting with the tank.
If it has a hose connected between the fill neck and tank, ensure it has no low spots in the routing. Check you vents as well. In order to get fuel in, air has to get out.
Chaseweston
Mine was doing this on only the rear "accessory" tank on our Valor. The vent line running back to the fill port was pinched where it passes through the frame just enough to not let enough air out, tripping the pump handle. I removed the fill port and recentered it in the opening so that the vent line wasn't pinched anymore.
