Having had my fresh water tank drop out I was interested to see a recall has been issued on this for the Avenue 32RLS and the Paradigm 295MK - see attached from NHTSA. I have sent an email to Alliance requesting more information...........
Just don’t run with the tank full?That's very interesting.
We have a 2022 295MK which I guess will be involved in this recall.
We haven't had any problems with the fresh water tank, but I wonder if we should use the trailer this spring before the recall is done?
We haven't received a notification of recall from Alliance, yet.
Just curious, how/where did you attach the Unistrut? You said below the coroplast, do you mean you left the coroplast in place and put the Unistrut outside of it?After a number of emails today I did speak with a Rep at Alliance (as a side note they called me and this is the biggest benefit to dealing with Alliance). They have only been dealing with the recall for a few days so they have no hard information. They are saying probably June before the recall letters start going out.
I did specifically ask the question about what an owner should do at this point. They would not give any guidance on this. This is an important question for us given that we are full time.
As a note - since our tank had dropped once due to a failed weld, I got to see what that supporting structure looks like. It is not as robust as I was expecting. For this reason, I installed two pieces of Unistrut under the tanks below the coroplast for added tank support - the Unistrut runs across the Rig. At this point I am going to run with that until we see the letters from Alliance on the recall.
