Failure to get any cable signal
I've made the connections, thrown the right switches, scanned for channels, and I NEVER get any cable signal irrespective of what RV park I'm at. I have an Insignia Fire TV. Please offer advice.
Richard
2023 Paradigm 340RL
Coltsdad
Our 2022 340 had the same problems when we got it. I found the junction behind the trim panel on the left side bottom of the stove was not made up correctly.
darrell
Did you turn off your antenna booster? Not sure where your booster switch is, but it will be a regular coax plate with a button and LED on it. Ours was in the front DS storage on our 390MP.
redommer
Richard
2023 Paradigm 340RL
Hello
I had the same problem with cable signal and was told to turn off my antenna booster… I have a 2024 alliance avenue 33rks and at 1st could not find a booster like my other campers until I looked in bedroom closet on the non entry door side and found the green light booster for cable and WiFi booster and solved my problem
Meanjean73
I’m trying to get cable in the RV park for the first time and nothing!
I hooked to the port labeled cable in the wet bay and nothing. Booster was off, nothing, booster on, nothing.
Why do I have two ports behind my tv? Neither is labeled?
Have you validate that you have a signal coming from the pedestal?
Have you gone into the TV settings and selected the correct input and performed the channel scan process?
The booster should be off when hooked to cable.
One port is normally cable or the Winegard Ant and the other could be tied to the Satellite Connection in the wet bay.
