Exterior Quick Connect size for hose
Our 3/8" coiled outdoor hose we got with our Delta 2026 252RL leaks all over the place. We need to replace the hose but having a problem finding a hose with the right size quick connect on the end that will go into the camper. Most seem to be 1/2 inch, but this is smaller. Is Alliance the only one that carries them?
Also, I have an older exterior hose from my previous camper, which I could use, but would still need to modify it to fit into the Delta's quick connect port. It has a 1/2 quick connect, which won't work with the camper. If I can figure out the size connection the camper takes, I could maybe modify the older hose.
Any help would be appreciated.
2 Allies
Just be sure it is an adapter that is compatible with the Valterra spray port if yours is a Valterra.
Thanks for the input. Looked at Valterra connectors, but couldn't find one like the picture I posted. If I look at the actual opening/ hole its only 1/4 inch. Not able to find anything that size.
Chaseweston
Any chance you can get a brand on the receiving end? Our Valor has valterra quick connects on it and I got the same adapter Bruce linked above for the door side and works fine other than requiring the whole family to join forces to push it in if I haven't connected in a while.
If you can identify the female side, or any branding, you're in better shape.
Otherwise, replace the receiving end with Valterra and join the industry standard that Alliance is for some reason not using on the Delta series.
jimh
I looked and didn't see any branding on the female end. My next step is to see if Alliance knows.
