Correct.........and the same issue exists if you use a 2-way hose splitter right at the connection into RV park hose bib.....just look inside the splitter and you can see the inside diameter reduction of the valve used. It really doesn't matter to most, but I was drinking at the campfire one night and thought.......what if I could take a shower at the same time the wife decides to do the dishes?I understand. I think he recognized that he would loose flow if he used a single splitter and that was why he used the quad splitter with the washer hose. But I could be wrong. What say you Mr. RockDr896?![]()
You had me at drinking around the campfire!!!!!!!!!!!Correct.........and the same issue exists if you use a 2-way hose splitter right at the connection into RV park hose bib.....just look inside the splitter and you can see the inside diameter reduction of the valve used. It really doesn't matter to most, but I was drinking at the campfire one night and thought.......what if I could take a shower at the same time the wife decides to do the dishes?
Same method just different material. Found that those plastic start leaking after a short time. switched to brass connections.I like the water-stop feature of the Melnor QD's They work like an air hose QD.
Ah HA!! Now we get to the truth! He was drinking by the campfire!! Explains it all!! Great things come to a relax mind.....even tho no one else can understand it. It made sense to you so that is all that matters!! Camp on!!Correct.........and the same issue exists if you use a 2-way hose splitter right at the connection into RV park hose bib.....just look inside the splitter and you can see the inside diameter reduction of the valve used. It really doesn't matter to most, but I was drinking at the campfire one night and thought.......what if I could take a shower at the same time the wife decides to do the dishes?
Light weight!! Jack's a mans drink!! LOL
Been using some of them 15+ years and no leaks on any. The plastic does suffer some UV damage if left in the sun for a few years though.Same method just different material. Found that those plastic start leaking after a short time. switched to brass connections..
Geroge,Been using some of them 15+ years and no leaks on any. The plastic does suffer some UV damage if left in the sun for a few years though.
I just like the water shut-off feature. Do any of the brass ones shut off like an air compressor hose does when disconnected? Brass WOULD be better.
So, is it the topic that has your head hurting, or is it the drinking around the campfire?🤣Wow! This subject has gotten to a point it hurts my head. I'll just leave my single connection as is and be happy!!
Meaning, wife can take a shower while I'm out by the campfire having a tody!!
Happy Glamping everyone and its getting to be that season very soon!!😂
Added 03/13/2026: Simple,,,,That's what we use- 1 domestic H20 hose w 2 way splitter = 1-1’ SS hose to city water,,,&1-1’ SS hose to the black flush connection. Dump each tank separately,,,black flush seperately,,,,,,,splitter inside heated pass thru,,,has worked for us for a long time.Did the same but all hooked up inside the wet bay with just a small section of hose to put thru the pass tru and quick connect to water supply with the pressure regulator and filter.
My bad, I was talking about the Melnor Quick Disconnects. Definitely use brass splitters. I noticed there are several "Full Flow" splitters on Amazon that do not restrict much at all.Geroge,
If you were referring to the splitter valve, yes, they do have them in brass, (see link). They also splitters that have more than just 2 as you will see when you look at the link. Not sure what the description means by 3.38 pounds per second. Coule they mean gal? That pretty good water flow!
BryanValRox, I'm not sure which yet, can't remember the topic and what camp fire? 🤪So, is it the topic that has your head hurting, or is it the drinking around the campfire?🤣
