I've recently purchased a new 321BH. It is a 2025 but was new and I had the stock ACs swapped out to Chill Cubes so that I could potentially run one of them off of an inverter if needed. Given that I won't be using too much power, is there a way I can still use the equipment that came pre-installed to hook to a Victron Multiplus II 3000w inverter to the current system? The unit has 400w of solar and the victron mppt charge controller. I have 2x Eco Worthy 280ah LifePo4 batteries. Can I wire into the stock solar prep with the inverter to run the outlets and 12v equipment that is on those circuits? My question is what equipment would I need to install in order connect to the ACs in order to power the Chill Cubes? I don't want to a complete system install. I want to leverage what is installed while also adding additional capability for the air conditioners. Thank you.
