rkmurtland
Bought my Paradigm 385FL on April 10th from Madison, WI. Drove it home to Virginia the following day. A couple days later I opened up the slides and wanted to extend the awnings, but neither switches at the main control panel worked - they did during our pre-purchase walk-thru! The second set up switches located in the pass-thru storage compartment work just fine. I contacted Alliance and they sent me two new switches. I was doubtful that was the problem as they worked fine before and having two go bad at once is unheard of. I swapped the switches and as expected - no change. Fuses are good. I used my Fluke and found voltage across the various connection points of the switches. See the attached diagram.
Anyone have any suggestions? Alliance is now telling me to take it to the nearest authorized dealership, but that's 100 miles away.
