cable tv issues
fireman0175
Hi, I have tried connecting to park cable tv ports with my power booster turned off. Every time I do not get a clear picture but static laced shows. Any suggestions?
Only recommendations I can make is to get a Smart TV that allows you can use WIFI. We use T-Mobile cellular WIFI and it has worked great. Now, having said that, we have always been somewhere where there is cell service. We have the little box at home and just un-plug and take with us in the RV. $50/month. The great thing about that is wherever you are, you always get hometown news, WX, sports.
If you do boondocking in remote areas, you out of luck but then again, with cable you are also.
fireman0175
yeah, we do that with an ONN device from W on the factory tv. But sometimes the Wifi is more like lofi but they have cable tv. Same issue with ATT. Perhaps I just have a crappy coaxial cable I am using and should try a new one.
Not sure about your rig but if I look behind my Nautilus panel, I have 4 cable connections just hanging there. I have never used them so I have no idea what they go to. I guess one day when I'm bored I'll attempt to track them down. I am sure that one is for cable, one is for SAT but no clue what they are all for.
Any chance that you need to change the input source on your TV? Possibly from antenna to cable?
Could also be a loose connection or a cable that wasn’t crimped properly.
Just some suggestions to consider.
fireman0175
I was wondering if there is a splitter somewhere in the basement that goes to the fireplace tv and to the bedroom location plus the power amp unit. With all the shaking from long drives on less than smooth highways and byways I always have to retighten plumbing and such. So, maybe connector is loose like you mentioned.
Kim Perez
If you plug into the park cable box and the other end to your auxiliary port I believe you will get any of the programs the park has available to them! Just what I have been told by another camper! I have not tried it yet but I will on my next outing! I hope this will work!
Kim Perez
Thanks I will try that! The issue for the living area is I will get some cable stations and perhaps it's just a matter of what is available to that particular park. Also I want to try plugging into the aux connection and not the cable connection and see if that will give me just the main channels like abc nbc cbs kpix!
thanks for the suggestion!
Thibodeaux
Just got a new 2027 Delta 252RL, cables for Satellite or Park cable are not connected yet, you have to figure out which one to connect to the back of panel behind the Nautilus panel! I lucked out on the first try, so I could hook up my Dish Tailgater. 👍
Hi Kim, I can’t say with certainty, but I am not sure that you will gain any benefit from the Aux connection.
Certainly, it would not provide any more channels than what the park hook up would provide by default.
At the end of the day, it is “just” a connection point that may or may not even be attached to any cable on the back side of the panel. We only have Cable and Sat. On our panel and only ever use the one marked cable when the park offers it. Otherwise we have varied success with the over the air channels picked up via the Winegard.
This diagram might help you understand the set up some.
Remember that you need to rescan channels when you move to a different location.
  • Coax Wiring .pdf
Kim Perez
Great help everyone!
Just to share....a friend said buy a new coaxial cable as well and not a cheap one there has been times for him that the cable was not good! Just a thought!
Top942002
1- Interference could be caused by the camp cable being located near the power line. Guidelines suggest at least 6" of separation.
2- I pulled the covers on all my cable plates and noted the colored cables. Ensured I positively connected to the correct source. Labeled them (bad memory ).
3. Used 50ohm termination plugs on all unused coax connections. This reduces dB loss to the active device(s).
Good luck. Image Interference when watching Avatar is annoying.
We have used cable at various parks and have had snow on screen at some of them. I thought it was camper but I think some cable hookups at parks are the problem as we have had good pictures at some.
Most parks cable is a thing of the past. Some old cable hook up that has been spliced a 1000 times is not cable? Most cable reception sucks!
get STARLINK.
