fireman0175
Hi, I have tried connecting to park cable tv ports with my power booster turned off. Every time I do not get a clear picture but static laced shows. Any suggestions?
yeah, we do that with an ONN device from W on the factory tv. But sometimes the Wifi is more like lofi but they have cable tv. Same issue with ATT. Perhaps I just have a crappy coaxial cable I am using and should try a new one.Only recommendations I can make is to get a Smart TV that allows you can use WIFI. We use T-Mobile cellular WIFI and it has worked great. Now, having said that, we have always been somewhere where there is cell service. We have the little box at home and just un-plug and take with us in the RV. $50/month. The great thing about that is wherever you are, you always get hometown news, WX, sports.
If you do boondocking in remote areas, you out of luck but then again, with cable you are also.
Not sure about your rig but if I look behind my Nautilus panel, I have 4 cable connections just hanging there. I have never used them so I have no idea what they go to. I guess one day when I'm bored I'll attempt to track them down. I am sure that one is for cable, one is for SAT but no clue what they are all for.yeah, we do that with an ONN device from W on the factory tv. But sometimes the Wifi is more like lofi but they have cable tv. Same issue with ATT. Perhaps I just have a crappy coaxial cable I am using and should try a new one.
Any chance that you need to change the input source on your TV? Possibly from antenna to cable?Hi, I have tried connecting to park cable tv ports with my power booster turned off. Every time I do not get a clear picture but static laced shows. Any suggestions?
Just got a new 2027 Delta 252RL, cables for Satellite or Park cable are not connected yet, you have to figure out which one to connect to the back of panel behind the Nautilus panel! I lucked out on the first try, so I could hook up my Dish Tailgater. 👍Not sure about your rig but if I look behind my Nautilus panel, I have 4 cable connections just hanging there. I have never used them so I have no idea what they go to. I guess one day when I'm bored I'll attempt to track them down. I am sure that one is for cable, one is for SAT but no clue what they are all for.
Most parks cable is a thing of the past. Some old cable hook up that has been spliced a 1000 times is not cable? Most cable reception sucks!We have used cable at various parks and have had snow on screen at some of them. I thought it was camper but I think some cable hookups at parks are the problem as we have had good pictures at some.
