Bathroom fan woes
Hotrodjohn
2026 36v11. New style max air fans with motion sensors. One unit works as it should. The rear 1/2 bath doesn’t. The fan will not function if the light is set to motion. The fan will function with the motion sensor turned off. The fan will work with the light on or off just not if set to motion sensor turned.🤔
I also saw your post on Connex 12 volt tv not working. Are both of these failing after a few months of owning the new Valor? We all know this is not your first rodeo...so I am sure all of this was checked before you left your amazing 340RL at the dealership for this new Valor.
Hotrodjohn
Rigs five days old. Pdi at the dealers a joke. I don’t try it there
Hotrodjohn
Sounds like the fan got to fancy Hot Rod! The more fancy they make stuff the more that can go wrong? IMHO
Still can’t believe you let the other one go?
Roll On HRJ! Roll On!
I got tired of my motorcycle complaining that it could not come with 🤣
This comment is not intended. to throw salt on the wound. A thorough extensive PDI is a must. You cannot trust the dealer or assume everything is OK just because the unit is new.o_O Nowhere in the process is there a thorough inspection of the unit.:mad: This is why you must conduct your own thorough PD Before accepting the unit and pulling off the lot. Unfortunately once you pull off the lot, Getting problems resolved involve a lot of red tape and are not as easy to resolve as they should be.
There are PDI checklist available on this forum. Yes I understand you can't catch every problem via the PDI but you must make an attempt and try to catch every problem Before you pull off the lot. The RV industry is shady and the getting warranty service it's not as straightforward as it should be. This is not just an an Alliance issue, this is industry wide.:eek:
These comments may not help Hotrodjohn at this point but hopefully they will benefit someone else reading this.
Curb your enthusiasm. Download the list and conduct a PDI before pulling off the lot.
