Alliance 310RL Air-conditioner?
treecatt
Yes I have one on the way from Amazon
It would also be helpful if you have outlet(s) that don't seem to be working. I recently lost power to the outlets in the bathroom and bedroom. Turned out it was a manufacturing problem. They wire inside the Romex was broke but still making contact until recently. Naturally, this occured right after my manufacturer warranty ran out and Alliance rejected the claim (even though it was obviously their fault) so I had to use the extended warranty.
The tech found the cause while working on the problem. When he pulled the bathroom outlet out the neutral wire in the Romex slid right out of the insulation. Had to replace the Romex wire run to the breaker panel.
DanNJanice
I have a 2024 Paradigm 310RL. I had to run off 30A service at a campground this summer. The 30A/50A adapter I have only connects power to what I will call Ckt #1. The bedroom AC is on this circuit. The two main living/kitchen AC's are on Ckt #2 which had no power. Don't know how you could get two AC's powered from a 30A service.
Hmmm, something doesn't sound right. Normally the single hot wire from the 30amp side is connected to both hot legs on the 50amp side. This provides both Ckt #1 and Ckt #2 with power. If yours does not work this way then I would suspect a bad adapter or other wiring issue.
treecatt
I'll need to investigate further. I admit I was surprised to discover only the bedroom AC had power when I used the 30A/50A dogbone.
