Adding extra run/turn/brake lights to the rear of trailer?
TonyG109
The lights came with 22 gauge wire. The extension gauge depends on length. The 10' and 15' extensions come with 22 gauge wire. The longer ones come with 18 gauge wire. Sorry for the late reply.
Added an auxiliary tail/turn/stop light with an inexpensive LED strip. attached with adhesive tape. Ran a piece of D-Line White wire raceway fitted into the end of the LED strip to the right side channel. After extending the wires and reattaching the 4 pin plug, ran the wires down the channel and then just connected it in the 4 pin trailer plug. Added a couple of zip ties underneath and buttoned things up.
To make the D-Line raceway usable I stripped off the adhesive tape that is only suitable for indoor use, cleaned it thoroughly, and mounted it with 1/2 inch 3m VHB tape. Here is the result...
