Though I understand how happy most seem to be with Boogey lights, and I have them installed too, I just do not think they are bright enough and I regret installing them. Frankly, they have little value in daylight in my opinion. There are different LEDs that can be used each having varying degrees of brightness, focus, etc. Boogey Lights use generic 5050 LED chips. They just do not give me the conspicuity I was hoping for. I wish I would have researched it with more depth before asking for them as a gift. Plus, Boogey Lights advertises they use the brightest chip available, and that assertion is just not true...not even close (though brightness is not the only element of conspicuity to consider). Anyhow, I know I am a dissenter on this, and I also know my position that they could be much better than they are is correct, and just want others to consider options...and Boogey Lights might be the best for many. I was also entirely unimpressed with Boogey Lights customer service when I addressed the lack of conspicuity their product delivered...basically a sorry for your luck response despite their inaccurate characterization as the "brightest chip available."
At first blush, the ABC that
@darrenlife installed is a much better solution if we are talking conspicuity. It has 548 leds in each 72 inch strip, 91 per foot. Boogey has 75 LEDs in its 52" strip, or 17 per foot. ABC has an intentionally designed diffuser (better). Boogey has none. In all conditions, presuming candela output is the same (ABC's will likely be much better), the two products are not even in the same conspicuity class by a very large margin. Dusk, dawn, nighttime, both will ad value. Daylight, when we do most of our driving, Boogey just does not cut the mustard.
I know I have some opinion and some facts here. Fact check me and you'll see that there are much better choices than the Boogeys when we are talking conspicuity for braking and turning. Boogey does have some features ABC lacks that might make it the better solution for some. Somewhat unrelated, and you can fact check me on this too, amber turn indicators (when SAE compliant) are vastly superior to red turn signals in every driving condition (there is science behind it).
