Hello,
I knew there was likely not going to be any info on this no matter how hard I searched (just not enough Delta info yet since they are too new!) so I decided to test for myself. I wanted to know how the 2 hots are distributed through the unit, because when using a 30A (single hot) to 50A (dual hot) dogbone adapter, it actually splits the hot into 2 branches. BUT if using one of those Y joiner-adapters where one leg is 30A (TT connector) and one leg is 15/20A (household connector), I want to know which one to give the 30A to and label it appropriately. (example: https://www.etrailer.com/RV-Plug-Adapters/Camco/CAM55025.html)
I have a F150 Powerboost with the 7.2kW generator. I used it to power our 294RK Delta, so I can use my Fordpass app while inside the unit to monitor the live power on each of the 2 hot legs (A and B is what the app calls them). Here is what I found:
Leg A:
Fireplace
Bedroom AC
Leg B:
Main AC
Microwave
GFCI outlets
General outlets
Converter
I suspect that the microwave/general/gfci are all lumped together because they are in the inverter prep loop. But I'm surprised that leg B is so loaded up! I would have swapped the ACs, or put the Converter on Leg A to load balance a little.
Anyway, given the above, I would give Leg B the 30A and Leg A the 15/20A. I do not know if other Delta models are done in the same way (especially those w/o a fireplace!)
SIDE NOTE: I tested the Main AC first on low, to see which circuit and it drew 800W steady state. I cannot capture the inrush because the app is a "pull" to refresh, not a live instantaneous reading. But the AC ran fine. Interestingly, when I tried the bedroom AC on low, it ran for about 2 seconds before it tripped my truck's genny as an overload on leg A. Hmmm.... these are supposed to be able to both run on 30A! I hope that was a fluke and not the norm. I did not reset and retest as I got the info I wanted and had limited time.
-T
Leg A:
Fireplace
Bedroom AC
Leg B:
Main AC
Microwave
GFCI outlets
General outlets
Converter
-T
