Wiring help 2024 310 RL 12V DC fridge
1bigtruck
Replacing 3 year old Norcold DC fridge (bah)
Would be nice to know which wire feeds it to ensure it has a 30A fuse or circuit breaker.
Also, in the cabinet beside the fridge is a receptacle with a small white circuit board.
Assume it feeds the 110VAC ice-maker in the fridge?
What’s the circuit board for?
Thanks!
Can't see it in your picture, but there should be a fuse on one of the wires coming off the resetable fuse. Should be ~10-12" from connection.
Yes...that is the outlet for the ice maker, should you decide to connect/use it.
By "circuit board" I think you are referring to the white block that has a Romex out the bottom and a round black cable out the top. If so — that's commonly called a Molex connector and it used to transition from solid copper Romex to a more flexible cable that moves with the slide out.
jagibson58
This is a picture of the buss bar in most Alliance models, unsure if they wire them exactly the same. Possibly suggest getting a helper with a good meter and check each 30 amp fuse by turning the refrigerator off and on inside the coach while your helper monitors the fuses.
I have in the past few months put a tag on a few of the cables and their attachment.
  • ALLIANCE PARADIGM 12V.pdf
