Alliance has produced a Quick Winterize Guide for the plumbing system on Alliance RVs. This guide is in the Resource area of the forum. Follow this link to that article.
IMPORTANT NOTE: Below are a few additional tips to make this a success:
- Use a short hose (4-5 feet) to draw the winterizing solution in.
- Set the winterizing solution at a similar height or above the water panel so that the pump is pulling it as horizontal as possible rather than trying to pull the fluid up from the ground.
- It can take a couple minutes to prime the water pump and have it start pulling the winterizing solution.
- Make sure the screen in your city water connection is clean of debris.
- It can take up to 4-5+ gallons of winterizing solution to complete the process (every floorplan will be different).
- Make sure the dials on the water panel are properly set to "Winterize" and water pump is turned on when trying to pull in the winterizing solution.
