Wi-Fi issues
dnitsche
Hi all,
I just purchased a new Alliance Avenue 23ML and am installing a Winegard gateway found the point where the power and antenna wires are. The color coding on the wires don’t match what the gateway. I have two reds wires and one yellow wire. The yellow wire is marked Wi-Fi and the red wires are marked 4g/5g-1 and 4g/5g-2. These connectors are threaded and the gateway is for push on.
Anybody out there come across this issue and where you able to resolve it.
Dan
Event Type
Other
Event Name
Wi-Fi issues
What's on the roof? Winegaurd 360+, Wingegard 360+ 5G, or something else? Sounds like you may have something else that the Gateway isn't compatible with.
When I added a Gateway to our Winegard 360+ the coax connectors from the roof were all push on.
If you have all Winegard equipment their customer service could help; they were helpful to me.
Taoglas TV Antenna
Starting in 2025, Avenue trailers are equipped with a Taoglas LoPro Connect 4-in-1 antenna model
MAR140.A.001. Similar to the prior antenna, this unit provides signal amplification of television and
radio signals and also is cellular internet ready and can be upgraded easily with a cellular
modem/router. It also requires no aiming or pointing to pick signals up.
Hi all,
Dan
Dan, Let us know what you find out about this. I tried a quick search — unsuccessfully — for cellular modems compatible with the Taoglas.
