MontanaHeaven
Full timers here in 310RL. Last late fall and thru winter we used the fresh tank and pump exclusively no problem.
In prep for this winter I figured I'd fill freshwater tank and test out the pump. Panel set to Powerfill and filled tank until it ran from the overflow . Set panel to Dry Camping then i turned on a faucet then turned on the pump. Pump comes on and water flows fine but with no faucets opened the pump cycles on then off repeatedly about every two seconds. I've checked hose connections behind the panel and pump area. No water leaks I can see. Mesh filter is clean as a whistle. No leaks in any cabinets.
Any advice/recommendations will be greatly appreciated.
Thank you
Thank you
