Good afternoon all.
I have attempted to drain the fresh water tank using the low point drain at the water tank behind the axle.
There is very little water flow there and I need to drain using the large drain valve.
I did the same procedure last season using the low point drain with no problem.
Is there a check valve in the line ?
What am I missing??
What am I missing??
