Has anyone attempted to use the onboard, low-pressure side of an RV propane system to feed propane to a portable dual fuel generator with the generator's supplied regulator removed?
My goal is to plumb a WEN dual fuel portable gen into the low-pressure side of my Delta and not use the regulator that comes with the generator. I plan to test this before buying needed parts.
If the low-pressure (already regulated) side of the RV's propane system proves inadequate at 11" WC, I plan to separate the 2 tanks (I replaced the 20s with 30s) and plumb the generator regulator to one of the tanks and run a dedicated line to the back of the RV where the generator will live.
Some pics and more insight as to what I'm up to: https://alliancervowners.com/forum/threads/generator-storage-for-delta-251bh.1572/#post-7832
