Valor 31t13 Fuel Tanks
KKT13
Does the Valor 31t13 have one or two fuel tanks. It appears to have only one 30 gallon tank for toys which must also provide fuel to the generator but most threads seem to indicate that toy haulers have two fuel tanks. Any help is appreciated
rayep
I have the 36V11 and it has 2 30 Gal Fuel tanks. One for toys and one for Generator. Not sure about the 32T13
KKT13
Thank you I am sure true for 31t13 as well. Trying to find the cause of generator failure . Probably pump , filter is good s ems to fail after system runs for 20 min.
Chaseweston
What generator is in it? and how does it "fail" after 20 min? Does it sputter and shuts down like it has run out of fuel? Does it idle ok and run normally under load for 20 min and then shut down?
HCL
Had the same issue on a 36V11 and it drove me crazy, long story short, found the fuel cap was not venting properly.
Loosen the fuel cap and start the gen set. If it runs more than 20 min it might be fuel cap and replace it with standard automotive cap.
