Underbelly
SNadler11
I noticed on our 2024 32RLS that there is a sag in the underbelly in the section behind the rear wheels. When pushing on it it feels solid like it is against something and I dont see any leaking. Has hanyone else noticed this?
Should be able to remove 1 or 2 of the rivets Alliance uses to look in there. Then use screw (metal) to reattach.
Chaseweston
I don't have the same model but looking at the floor plan and specs, it is highly likely what you are feeling the underbelly up against is the kitchen sink gray tank. Either pull some shot pins to peak in there to confirm, OR, empty your kitchen gray tank and push up on the underbelly at this location and see if it now pushes up more without as much water in the tank. It is actually pretty crazy how much the holding tanks deform when full. They really sag down in the middle of the tank.
Chaseweston
#10 rings a bell for mine as well. I replaced them all across a few times pulling the underbelly for various reasons.
pro tip for shot pin removal: put a 1/4" tapcon bit on the head of it and spin it while you pry down with a flathead or small breaker bar. They pop out pretty easy like this.
