Basspr72
Hello - Does anyone know if insulation is installed between the flooring area and the underbelly corrugated board on the Valor TH, specifically the 42V13? Long story short, we recently had an issue with our half bath water lines freezing. Upon removing the panel in the garage under the washer/dryer hookup area, I reached down into the floor hole behind the fireplace where the pipes come up. I could put my hand in this area and move it around about 6 inches in all direction, could even feel the bottom corrugated board under the rig, but felt NO insulation anywhere.. Is this normal? If so, this could explain the freezing lines as if there is no insulation and the heat from the basement area can not reach this area, well there would be a weak point for air - right?
