Which Les Schwab? The one at Queensgate did not have a jack to reach the main beam lifting point.I had Les Schwab install mine. However as I stated, if you have 16" tires (which I believe you do), you will need to upgrade the stems from Nicholas Manufacturing, and then those TPMS sensors only read up to 100PSI and I believe your 16" tires are inflated to 110PSI.
Good luck and have fun!
//KMac
Thanks for the great link to Nichols mfg. I do have 16” tires and they do go to 110. Does anyone out there know of a sensor that will read up to 110psi and tie into the gmc infotainment center for monitoring?I had Les Schwab install mine. However as I stated, if you have 16" tires (which I believe you do), you will need to upgrade the stems from Nicholas Manufacturing, and then those TPMS sensors only read up to 100PSI and I believe your 16" tires are inflated to 110PSI.
//KMac
