TheRayQuelines
OK so how does one access the tail lights on a Paradigm? Specifically a 372RK.
I thought I might access from under/behind the light but do not see access.
Noticed light was out (all but 1 LED) and appears to be condensation and possible some mold, in the lens. I need to pull the lens clean and replace the LED's hopefully that will solve the issue. If not I will replace and re-caulk around the lens not sure where else the moisture is coming from.
Thoughts?
Thoughts?
